whomadewho »
https://forums.nicoclub.com/whomadewho-u165512.html
Tue Jul 05, 2011 7:16 pm
I do not want to sound negative,but unless I had a donor vehicle where I knew the a/c worked or a machine (or assesses to) that can reclaim freon in case the system does not work, I would hesitate doing it. Given the year (1990) there is to much that can go wrong. The condenser could leak or be plugged.the expansion valve could be bad,the receiver drier should be replaced,the compressor could be bad. Plus a lot of time installing the evaporator and duct work. Just an opinion if I really wanted to install A/C in a 1990 vehicle I would save a lot of work & time and find a aftermarket evaporator that uses R134, with the expansion valve built into it, that mounts under the dash,replace the condenser & receiver drier or at least have the donor condenser tested and go with new low & high hoses. The only thing you would need form the donor vehicle is the compressor and brackets.
