Installing a Walbro - Do I Need an FPR?
4felix20
Car: Emerald Blue S14
i've been searching around and it's just getting me more confused.
i'm aiming for 350 hp and i'm running a super 60 T3. I do need a better FPR to handle the walbro pump, right?
nissanfanatic
Car: 1992 Nissan 240sx SE
nope. Not unless the stocker is malfunctioning.
4felix20
great.i don't need an FMU...do i?
Nismo_Freak
Car: 89 Nissan 240SX
No, I would suggest a better FPR though. You will have high idle fuel pressure with the greater flow pump.
Red-KAT
Car: 1995 240sx-se ka24det
I would upgrade also. mine was holding me back at only 8psi.
turbo98_240sx
Car: computers, cars, anything that can do something and be made to do it faster stronger or better
what are the choices besides the nismo FPR?
240DRFT
i think boost designs carrys a fpr too
89porkchop
Car: 89 240sx
i use to run an aeromotive rising rate fpr-
Red-KAT
89porkchop wrote:i use to run an aeromotive rising rate fpr-
I run an Aeromotive 1:1 rate... Good for like 800hp of flow.
WDRacing
Any adjustable inline FPR will work and can be used inconjunction with the stock unit to increase fuel pressure.
If your running to rich then you'll have to settle for a direct rail bolt on.
Nismo_Freak
WDRacing wrote:Any adjustable inline FPR will work and can be used inconjunction with the stock unit to increase fuel pressure.
An inline FPR will do nothing for the fuel pressure if you are talking about the feed line. On the return line you can only raise the fuel pressure as the stock FPR will open at ~34 psi at idle.
It would be a waste of time and money to set up the FPR in this manner. It's best to just remove the stock unit and replace it with either an AN (better suited for Aeromotive FPRs) or a barb fitting.
WDRacing
Dude...reread what I posted. You simply reworded it ...I said you have to use a direct rail bolt on to decrease your fuel pressure and I said you can use it inline, meaning between the rail and the tank on the return side since everyone knows the reg goes on the return side. And it's only good for increasing the fuel pressure.
So it's not a waste of time...Increasing your fuel pressure is a great way to get more WHP out of whatever injectors your currently running.
Nismo_Freak
WDRacing wrote:Dude...reread what I posted. You simply reworded it ...I said you have to use a direct rail bolt on to decrease your fuel pressure and I said you can use it inline, meaning between the rail and the tank on the return side since everyone knows the reg goes on the return side. And it's only good for increasing the fuel pressure.
Ah well I get what you were saying now.
I was understanding inline as in installing it on the feed line, which I think we both agree would be a retarded thing to do.
FPR's have the side benefit of lowering your idle pressure cause the crappy stock one can't flow anything. Plus they look trick and idiots always tend to ask "what is that"
240SicknessX
Car: 96 240 SE
Nismo_Freak wrote:No, I would suggest a better FPR though. You will have high idle fuel pressure with the greater flow pump.
now if you have an ecu tune for 370cc injectors w\ base pressure of 43.5 (vac line dissconnected). Then you install a higher flowing fuel pump (walbro 255 or z32). would the fuel pressure increase throw the whole tune rich all the time or only when the ecu is in closed loop? based off the o2 in open loop, the ecu would be able to adjust how much fuel the injectors put in even though the fuel pressure is higher.
ive seen 16 psi increase of base fuel pressure with a stock fpr and a walbro255 pump.
Nismo_Freak
Just avoid the whole situation and get a proper FPR.
1WheelWonder
Car: 1991 Nissan 240sx
How hard is to install a fpr inline and does anyone have a good recomendation for a fpr?
89porkchop
Car: 89 240sx
1WheelWonder wrote:How hard is to install a fpr inline and does anyone have a good recomendation for a fpr?
aeromotive 1:1
240SicknessX
Car: 96 240 SE
i was going to do that anyways, i was just wanting to know.
