[email protected] »
https://forums.nicoclub.com/mr-sahatoo-hotmail-com-u122613.html
Wed Oct 07, 2009 1:38 am
vacuum gauges areee sort of "poor man's" fuel mileage indicator when vacuum is low, you are burning more fuel.
heres the chart
The following readings DO NOT apply to turbocharged engines. All readings are inches of mercury (in. Hg.).
ENGINE STATE VACUUM GAUGE READING INDICATION
Steady idle (800-1200rpm) Gauge steady, 17-22 Normal & healthy
Steady idle (800-1200 rpm) Intermittently drops several needle divisions Sticking valve or broken valve spring
Steady idle (800-1200 rpm) Steady, low reading, 8-14 Small vacuum leak or valve timing off; could have low compression/worn rings (verify with a compression or leakdown test).
Steady idle (800-1200 rpm) Steady, low reading, under 8 Vacuum leak (check brake booster, vacuum lines, etc.)Idle (800-1200 rpm) Needle drops sharply on a regular rhythm Burnt valve, or a valve with clearance too tightIdle (800-1200 rpm) Needle drifts up & down, along with rpm drift Mixture off or small vacuum leakIdle (800-1200rpm) Vacuum gradually drops Excessive exhaust back pressure (plugged muffler or catalytic converter)Idle (800-1200rpm) Intermittent fluctuation Ignition miss; sticking valveIdle (800-1200rpm) Steady, above 22 Ignition timing may be too advancedOpen & close throttle quickly Drops to about 2, jumps to about 25 Healthy engineOpen & close throttle quickly Drops to 0, jumps to about 20 May confirm worn rings (especially if idle shows only about 15-20) Verify with a compression or leakdown test.
engines with performance camshafts tend to read lower vacuum. readings are also lower at higher altitudes; the rule is approximately 1 inch of mercury for every 1,000 feet of altitude gain.
Everything else aside, a high vacuum reading tends to indicate a healthy engine.
its the science behind it is honestly what i like
