Infinitiguy19 »
https://forums.nicoclub.com/infinitiguy19-u84424.html
Fri Nov 21, 2008 7:03 pm
I called IOS and they told me that the Throttle Position Sensor changes ever six months and they need the VIN. So I know on the 1991 Q45 the TOS voltage should be between .4 and .5 volts and the 1993 Q45 TPS be about .7 volts.
So if I were to install the 1991 Q45 TPS sensor on my 1993 would I set it to .7 volts or between .4 and .5 volts?
And please I know new is best but I want to see if I have a faulty TPS because my laptop consult couldn't read the closed throttle position switch on the TCU AND I can't complete the AT-CHECK which means by process of elimination the TPS or Closed throttle position sensor is bad.
