spreprts »
https://forums.nicoclub.com/spreprts-u87597.html
Wed Dec 03, 2008 4:16 pm
The factory alarm rearm should be a green/yellow in the same area as the disarm. And your are gonna hook the H4/6 brown/black from the starter to it. I usually don't hook this one up, never hear any complaints from my customers. But it's up to you. If you didn't get the door locks figured out yet, you are gonna take the positive lead from your meter and tap it into 12v and the negative into your door lock wire suspect. The meter should read 0.0v and then when you hit the door lock/unlock button on the door the meter should go to 12v thus the negative trigger completing the circuit. Whew got that out. Good luck man. Let me know if you need more help.
