NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Wed Aug 31, 2005 6:50 pm
Well didnt fully complete it today. But the clutch and flywheel are in. Nothing really to see there as it is inside and appears stock. The Nismo diff is a build unit. You do not get the whole differencial assembly. you get the lsd portion of it and new axle flanges. You must reuse the ring and poinion gears as well as the housing. Basically when I am done it will all look stock. On the stillen short shifter he has opted to use the stock knob?? I questioned it twice and he stated he liked the original knob so it to will look stock when done. I did find this car has carbon fiber front and rear bumpers with side skirts The bumbers are body kit style. I only knew they were carbon fiber by looking at them from underneath since he had then painted to match the car. He also has a carbon fiber spoiler on it. The only thing aside from the body kit look that appears custom are the einkie[sp?] wheels.
I have the diff mostly back together I just need to set it up in the moring and it will roll out. I cant push it since it needs to go through a break in process. But I drove it before hand. Something has been done to this car I cant see as it has an enourmous amount of power as compared to a factory set up and When you romp it , it sounds like it has custom exhuast but the pipeing and muffler are all stock. The only thing I saw under the hood was CAI.
So no pictures to be had.
Note: the flywheel,pressure plate and clutch are NISMO. He didnt opt for the T/O bearing either which I questioned.
The Nismo diff comes with the what I mentioned above as well as flange seals,both bearings, and a 2 qt cointainer of synthetic 80w-90 gear oil. And 2 cool sticker you can put on your windows..lol
