installing a/c
jt15833
Car: 95' 240SX
i have the CA compressor so i will most likely use that. I had dohc KA and its an s14. as far as i know, i will have to have the CA ends welded onto the KA lines and use the CA compressor. as far as wiring, anyone tackled this? And also, will i need some kind of pressure or cut off switch i keep hearing about with RB guys? gettin hot outside
jt15833
Car: 95' 240SX
no ones running a/c?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
jt15833 wrote:no ones running a/c?
I dont know how it is on the S14, but on the S13, you use the same plug for the A/C. Its just a single terminal plug.
tyrannix
Car: go big or go home
its been so long since i took teh KA out of the shell, which harness was the AC plug on? the left side of the bay harness?
(and anyone have a CA compressor?
jt15833
Car: 95' 240SX
so i dont have to worry about it over presurizing and blowing up or anything? just install everything, get belt tight, fill with r12(? or 134a??) and plug in the single a/c wire to the compressor and make sure that wire sees 12v when the a/c button is on??
