installing a/c on a non a/c 240sx
nihon
hi i have a s13 coupe that did not come with ac or heater, is there a write up anywhere that tells how to install a/c?
because i came across a FULL a/c set fora good price
its a dohc
jessetang
Car: 1995 240sx
You just have to read the FSM like 845234905 times and maybe you will think it out how to do it.
If you are doing it yourself, it will not be a 1 day job. These are a few of the big pieces install.
ACRemove radiator to put the condenser in.Install the AC compressor and belt.Route AC lines.A few relays and fuses for the system.
HeatTake off dash.Put the heater core and the blower motor back in.Route engine coolant lines back to the heater core.Reconnect the cable to control the coolant flow.
Assuming the owner before you removed the head/AC system, you really need to see how hardcore he/she took the system out before putting one back in.
