Installing a Bunch of Stuff
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
So today I was in the process of installing my oil cooler, transmission cooler, oil filter relocation kit, and the following gauges: vacuum/boost, transmission temperature, oil pressure and oil temperature.
I’m using 2 B&M transmission coolers like these: http://www.racerwheel.com/bm-70265.htmlThey are aluminum staked plate, which are more efficient then tube and fin, so you can a use a small one. They are very universal; you only get the core, which can be bad, since you have to buy everything. I’m using one as on oil cooler and the other as a transmission cooler.
The oil relocation kit is a Perma Cool: http://www.permacool.com/Catalog/Cat_page27.html
And the gauges are all Autometer sport compact serieshttp://hp.autometer.com/produc....htmlI choose these because they are the closest match to my stock gauge cluster
Today I only got to do the transmission cooler and temperature sender. And mounted the oil cooler.
I got the best place to mount them, instead of mounting them in front of the radiator and air-conditioning condenser, which will block air flow and the coolers will just warm the whole system up, it defeats the point of having extra coolers. So what I did was cut two holes in my bumper that are designated for fog lights and mounted the coolers right in front of them, so they have direct air flow, and won’t restrict the main cooling system
This is before they were cut, notice the two holes on the bottom right and left on the dumper
My transmission fluid is routed in the following way, goes out into a T fitting where on one end a temperature sender is hooked up, into the radiator, then into the cooler then back into the transmission.
Have a few pictures
On the left is the future oil cooler.
Both cooler installed
Tomorrow hopefully I will install the oil relocation kit, put the temperate and pressure senders. Route the oil cooler, and install all the gauges.
How is this KAT related? Well this is the first step on my turbo kit, I have an oil cooler many over look because when the turbo is oil cooled it puts extra stress on the whole cooling system.
Updates and more pictures coming tomorrow
JonnyB4Real
lookin good, you got a replacement bumper to get air to those coolers or are you gonna cut out those areas where it looks like fog lights should go.
I also thought about doing this for my integra a few years ago but was too lazy back then, props ;)
chandler
Car: 91 civic hb & 96 S14
let us know if the filter relocation kit works, does it fit the threads on a KA? what filter do you use then?
Checkered-Member
JonnyB4Real wrote:lookin good, you got a replacement bumper to get air to those coolers or are you gonna cut out those areas where it looks like fog lights should go.
I cut the holes, here is the finished product
And here is the T-fiting with the temperature sensor
chandler wrote:let us know if the filter relocation kit works, does it fit the threads on a KA? what filter do you use then?
the oil relocation kit works and thread to the block you can use the stock filter. What they did is have an adapter for the block and an adapter for the filter mounting thing.
When I run out of hose, and the T fitting I had didn’t fit after replacing it twice, I called it quits put the stock oil filter back on, assembled the car.
All I have is wire the gauges
JonnyB4Real
nice job
Checkered-Member
Update:
worked out the problem with the temperature sender, turns out it is supposed to be grounded...and while doing that I think I broke one of the gauge, I emailed autometer about the problem see how that turns out.
Installed oil temp and oil pressure gauges, everything looks sick
oil pressure installed but sender isn't hooked up...because I don't where it goes, any help will be much appreciated.
time for some pics: (higher resolution is available in the first link in my sig)
TurboKA37
is that the sport comp. series gauges? if so how are they in the dark? do they light up well?
TurboKA37
looks like a really sweet install too by the way :)
Checkered-Member
TurboKA37 wrote:is that the sport comp. series gauges? if so how are they in the dark? do they light up well?
Yes they are, there is a 194 bulb in the back of the gauge, its pretty bright, however I replaced them with blue LED’s to match my gauge cluster. I'll try to take a few pictures of them light up
Checkered-Member
Firs two are with the LED’s (sorry for the poor quality, digi cam doesn’t like the dark)This one is with the stock bulb and a green cover that comes with the gauge
TurboKA37
looks good. i like the blue much better than the stock color. what gauge looks maxed out?
GlacierFreeze
Car: '97 240sx (the tortise)
What about rocks hitting your coolers? Couldn't it cause a leak?If so, you could throw some flat black mesh down there.
Checkered-Member
TurboKA37 wrote:what gauge looks maxed out?
BOOST...HAHAHA JK
its the transmission temp, I think I broke it...emailed autometer about that...see what they say
Checkered-Member
GlacierFreeze wrote:What about rocks hitting your coolers? Couldn't it cause a leak?
aaaah That’s the beauty of "staked plates", they are extremely durable:D
GlacierFreeze
Ahh okay, haven't really read up on coolers that much.
UncleBen
Car: '05 Infiniti G35 Sedan Sport
'98 Nissan 240SX LE A/T
'95 Nissan 240SX SE A/T
Looks awesome.
Now for the removal of the checkers ;)
