coledog188 wrote:Hey guys,
I just picked up an 03 QX4 (pics up tomorrow) and I have a brush guard I bought for my old 98 QX4 but it didn't work for it because it was for a newer year.
In any case, I know it'll fit on the 03. Is there anything special I should do or need to know about installing it on the 03? Will the bolts from the front towhooks come off and then go right into the brush guard and hook it all up correctly?
I didn't get any instructions with the guard, so I'm just being safe.
Thanks a bunch.
Congrats on the new '03, you're gonna love it. I put a grille guard from a 99 on my 01. If it's the same setup, which it should be, all you have to do is:
1. Remove the Fog Lights (1 Screw and 1 Hex Head Bolt, I think a 10mm)2. Drop the tow hooks, I used an impact gun because it was tough getting enough torque out of a conventional socket/ratchet without stripping the bolts.3. Bolt the new grille guard up.
Because of the hole patterns I was only able to use 3 bolts on each side. It's tight around the bottom of the bumper cover and it will flex slightly but once it's up it'll look completely normal and badass!
Billy
