what he said. Boost controllers are universal, and you are better off just buying a new one to make sure that you have all the components necessary for the install. All a boost controller does is prevent the wastegate from opening by limiting the pressure to the actuator. I have a blitz on my RX-7, but I may go with a low cost mechanical boost controller for the RB. They are around $70Electronic boost controllers are ususally around $300 new.dekand wrote:why dont you just get a better boost controller... it doesn't have to be rb20det specific...
I am considering just getting a new one.jayz706 wrote:are you still gonna use the the boost controller? I have a pressure sensor if you will sell it to me.
takes about 15 minutes. You cut two wires and then connect the two new wires. very easy to do. Don't forget to get a fuel pressure regulator!eLEmEnT wrote:Oh.. and a new fuel pump, seems like everyone uses the walbro 255 pump.. How hard of an install is that? and is this the one right here:
http://cgi.ebay.com/ebaymotors...=WDVW
