You get a cleaner sound!XxXSnake23XxX wrote:So you are underpowering your sub and you wont get its full usage out of it. I would recommend getting somewhere in the 300-350 or even 400 RMS range. More power is better then less power.
You and me are in the same boat I also have the tech package, so I am planning on using an amp with high level speaker inputs so I don't have to buy a hi-lo converter and the intaller doesn't have to go into the dash to hook up the amp.dangeris wrote:I've actually been contemplating on integrating subs into the stock sound system too. I have the Bose with Navi but since the trunk space is very limited, I'm thinking of making an enclosure that will not not take away more of the already small trunk space.
In regards to your amp , do you know what it actually puts out RMS. By that I mean, does your amp come with a birth sheet? Rockford fosgate amps and subs are always underrated, whereas most other companies overrate their amps.prlwhitecoupe wrote:Hey guys (and gals)
I just purchased a JBL GTO1204BP subwoofer. I will be getting a JBL amp as well sometime soon. I got some issues though. I know it would be a good idea to upgrade my Bose factory deck; but the problem is I want to retain the the stock bluetooth and steering wheel controls, not to mention the XM radio and 6-disc changer; my understanding is there isn't an aftermarket system out there that will be compatible (unless the factory 3.5 nav system was installed). All I want is a little more OOMPH from my system. This is my first car, and my first system. I've known many friends who have had crazy *** systems...but like I said, just a little more OOMPH for me, nothing crazy for showing off.
I know I will require a converter that will bypass the factory Amp/System...other than that...what are your thoughts on a capacitor? Good idea or not really required?
Here is the sub:
http://www.crutchfield.com/S-Q...O12BP
Here is the amp I will be getting:
http://www.bestbuy.ca/catalog/...20103
Installation will be from a car audio shop...NOT BESTBUY.
Any suggestions or advice will help...
some questions I have are;
- Will I be taking full advantage of the sub's power even though I'll be using the factory deck?
- The amp I am going to buy; will IT take full advantage of the sub's power? (I will not be upgrading the sub)
Thanks Alot!
If an amp doesn't state that its stable at a certain ohm, then its for a reason. Some amps are even 1 ohm stable, but no audiophile would suggest running an amp at 1 ohm, even if its stated to be stable.notaverage wrote:Is BOSS any good for car amplifiers?
I am looking at the BOSS GT1000M amplifier, which is rated at 200 watts RMS @ 4ohms.
It doesn't give ratings for 2 ohm operation, but I called Boss Audio, and they said the amp is operable at 2 ohms, and will double it's output.
Any comments on this?
Dangeris, this is true, but if you use the high level inputs, you will have to splice the wires going from the factory deck to the amp high level inputs. If you don't, you will lose volume to your rear speakers. If you do, you are essentially connecting the high level inputs to the same wires going to the factory amp, thus defeating the purpose. Again, you gotta keep in mind the factory amp.dangeris wrote:There are a variety of amps out in the market that both have low level and high level inputs. All depends what you're looking for. Obviously the latter will not need RCAs. All the amps that I have bought in the past came with high level inputs so I would imagine 8 out of 10 amps out in the market today will have those...but I could be wrong.
Dangeris, your response was spot on! That is always a good idea on how to run the wires. Also, YES, the remote wire will need to be run from the remote turn on wire on the factory harness all the way back to the amp. I can't recall the wire color off the top of my head, but by now, there should be some wiring diagrams for the A/C floating around on the net!dangeris wrote:As for running your wires.... ALWAYS ALWAYS ALWAYS run your power on one side of the vehicle and run the RCAs (if you're going that route) on the other side of the vehicle or as far away from the power line. If not, you'll get humming that will annoy the crap out of you! As for your remote wire, I'm not quite sure where to hook that up too. I would imagine you'd have to run that back up to the HU so the amp goes on when the stereo is powered.
So, the line out converter ALSO has rca outputs, and you could use these to connect to your amp.
I hope that all made sense!
Don't be confused young padawan! Just get the amp that you want and make sure the RMS of the amp is slightly more than the RMS of the sub, get line out converters, a set of good quality RCAs and hook everything up. Remember what I said about separating your power from your RCAs or you'll get humming.notaverage wrote:
You confused me
I figured splicing the wires and hooking them up to my hi level input amp would be ok.
he asked about jbl.. JL is a great company, jbl is a slight step down imodangeris wrote:
JL makes great amps and subs IMO but the best set of speakers I've ever heard and listened to are a set of FoCals components
if i understand him correctly, i think he means fiberglass. its the only way to get around the contours... if he's talking fiberglass, that'll be like $200 for each enclosure....XxXSnake23XxX wrote:ask a shop to do a custom encloserit shouldn't be more then 200
I came very close to buying this box since it was so cheap and it was the only one that had the proper dimensions. However, when I called to ask if it was made of 5/8" or 3/4" mdf they referred me to the manufacturers website which was gone, and they also gave me the phone number which was out of service. IMO the box is far too important to be taking a chance on, so I'm just having some trusted car audio guys around here make me one.notaverage wrote:
I don't have to power tools to build the sub box myself, so I was planning on buying the box below from sonicelectronix. At a 11.5" height, it should fit in the back of my trunk pretty snug, AND it's very cheap, cheaper than if I made my box myself.
http://www.sonicelectronix.com....html
Im not sure of the color of the wire either. But, Ive found the easiest way to run wires (power, rca's, or remotes) to the trunk is to pop out the cup holders in the back and use the good old wire hanger method to pull them to there from the front kick panels. Once you have them there then you use the hanger to get it to the trunk. Just thought I would throw that out there because it saved me a TON of time, not having to take out seats and door panels.dangeris wrote:
Does anyone out there have any insight on this?
Will using polyfill (link below) fix the "hollow" problem for enclosures with less than the minimum required volume?dangeris wrote:I don't think any one has come out with those yet but that's exactly what I'm wanting to do. The only concerns that I have is the total amount of cubic feet. My Kappa 10.1s require 1.9 sq.ft of airspace. Subs installed in less than what is required for airspace sounds very hollow.
I'm thinking of putting a Kicker Comp VR 10" (which requires a minimum of 0.8 cubic feet of airspace in a sealed enclosure) into an enclosure with only 0.7 cubic feet of airspace. Anyone think it's possible to do it and make it sound good?
