rmezz13 »
https://forums.nicoclub.com/rmezz13-u82416.html
Fri Jan 30, 2009 10:01 am
1.) Comes with built on oil system2.) Comes with front mount (not an upgraded option)3.) More powerful, more efficient4.) Easy install then just pay for tuning separately5.) Because i said so
Vortech is good and a sponsor for nico (doesn't mean anything just thought i would mention it)
Personally no matter what you decide, i would upgrade the fuel system - bigger injectors and an intank instead of inline fuel pump, just to be sure your getting proper fuel. Then i would have it tuned at a conservative 380whp instead of the 400 it is capable of. Mine as well keep it safe instead of pushing limitations on stock internals. Also you are going to want to look into a timing retarder/monitor thingy (don't remember what they are called) that will correct your timing under boost throughout the entire power band - neither kit comes with one.
Don't know what i missed but something else should be in there.... someone can fill it in - i gotta go workout, i'll check back later
