180crafter »
https://forums.nicoclub.com/180crafter-u554.html
Sat May 01, 2004 12:51 pm
There should be no issues at all. The fuel Pump has little to do with the level signal. If it was working correctly when u put it in, and you followed all of the instructions, it should be working right.
Now, What I would do is remove everything again and double check that the float is not caught on anything. I remember when I did mine, The little wire sensor part that goes in the tank was heavily rusted, with lots of rust on the portion where the float signal actually swipes the wire contacts. I gently used a small peice of sandpaper to scrape some of this stuff off. Never had an issue.
Now dont ask me about the bursting lines.....
