installed today
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
jim wolf pop charger, asp under drive pulley, HI overdrive pulley,electric fan swap
will keep posted on how this goes....any suggestion on what i can hook the electric fan to so that when its only running when the car is on???right now its on a switch and im not really liking that...
let me know-K
Jakw
Car: 1993 J30
You should try to rig up the fan so that it is on a temperature-controlled switch. I had the fans on my old Z31T on switches (came that way), and it was a pain. You should feel a bit of a gain with that pop charger and UD pulley, as long as everything else is running well.
I'm curious as to how noticeable it is, though.
kbflip02
2006 Infiniti G35x
the throttle response is a lot better, however im noticing the gas mileage decrease slightly...im not sure if its getting lower or my foot is just getting heavier....will keep posted
gr8scott72
Car: 1994 Infiniti J30t
kbflip02 wrote:the throttle response is a lot better, however im noticing the gas mileage decrease slightly...im not sure if its getting lower or my foot is just getting heavier....will keep posted
Heavy foot.
brandonjustice93J30
Car: 1993 Infiniti J30
I'd be willing to bet on heavy foot as well...lol
Defiant
Car: 1997 J30
Your foot's probably trying to bring the noise levels up to what your ears are used to. I doubt the added alternator load -and it would not be insignificant- would be more than losing the fan drag.
kbflip02
2006 Infiniti G35x
i was told that since the pulleys are spinning faster that is what is causing the gas mileage to be worse...im not entirely convinced though...my foot is definately not heavy or at least wasnt on the last tank u put in and it was 13.8 gallons of 93 octane @ 220 miles...something must be wrong...any ideas???also i overheated in stop and go traffic while my A/C was running so today im installing a cooler thermostat to see if that helps...oh and i finally put my 2 10's in the trunk w/ an Alpine 1000W amp...sounds great...now i want to replace the 6 x 9s in the rear deck though...either that or install bass filters...not sure which way to go yet...any ideas???
on another note i was told that instead of doing all the work i want to to the motor i should just get a 50 dry shot of nitrous....maybe the motor could handle it but im not about to try that experiment...lastly my suspension guy told me that i could buy universal coilovers and throw them on the J...dont know what to make of it...
***special note on under drive pulleys***dont mess up the belts that came with them b/c if u do its a $%^& trying to find replacements w/o going back to the original place u got them...also when installing the HI water pump pulley get some washers so you can space it out otherwise the belts rub and then they shred...not fun...
-K
gr8scott72
kbflip02 wrote:i was told that since the pulleys are spinning faster that is what is causing the gas mileage to be worse...im not entirely convinced though...my foot is definately not heavy or at least wasnt on the last tank u put in and it was 13.8 gallons of 93 octane @ 220 miles...something must be wrong...any ideas???also i overheated in stop and go traffic while my A/C was running so today im installing a cooler thermostat to see if that helps...oh and i finally put my 2 10's in the trunk w/ an Alpine 1000W amp...sounds great...now i want to replace the 6 x 9s in the rear deck though...either that or install bass filters...not sure which way to go yet...any ideas???
-K
Underdrive pulleys make the accessories turn SLOWER not faster. That is the whole point of them. Make the accessories turn slower and that doesn't use as much power and frees up the power back to the motor.
kbflip02
2006 Infiniti G35x
i understand now scott...thank you...anyways i just came back from the muffler shop since i had a pretty nasty exhaust leak i couldnt hear over my 10s and flowmasters....havent driven it much but seems to have done the trick...will keep posted though
