tar0icy_w/tapioca »
https://forums.nicoclub.com/tar0icy-w-tapioca-u13561.html
Sat Aug 07, 2004 10:55 pm
205/60/15 is the larges diameter u going to fit in ur car (the total diameter including wheels and everything) with the cover. being heavier and stuff i'm not suprise, so either go to 195/60/15 or 205/55/15, or drive it real carefully until u get bigger rims and match it up w/ the right tires, the formula is on tirerack.com, its like thiswidth of tire (205) times the sidewall size (60/100) then times 2 (because there are 1 sidewall on each side) times the diameter of the rim itself (15 x 25.4mm) your should come out to be around 627mm, besides 205/55/16 any other tire+rim combination will be smaller then that, hope u take care of it soon because we wouldn't want to burn anything
