skydragoness »
https://forums.nicoclub.com/skydragoness-u193.html
Wed Nov 02, 2005 6:33 am
If your'e referring to the vibration coming from the rear-end, no it doesn't happen in 4th gearI could check the fluid I suppose. My bf and I put in Redline 75w140NS in it in the garage using a pump-gun thingy thru the side fill hole because i couldn't get the short-shifter out that night (couldn't get the snap ring out for the life of me). Did that job in July I think. When i first bought the car (June), the transmission was really pissed about going into certain gears. No grinding, just straight-up resistance to the point that I would have to double-clutch it to get it going in 1st or 3rd. After we changed the fluid to the Redline stuff that went away completely, and the car doesn't have the obligatory 3rd gear grind.
I don't know if this helps with your diagnosis, but i used to take this downhill slope to get to class, speed limit was 45mph, so i'd put it in 5th and just coast down letting the engine keep it at a decent 50mph or so. Before i had my catback put on (which muffles out a lot of little noises but creates new ones) I noticed that if my foot wasn't on the accelerator, and i was coasting down the hill i would hear a slight humming until i dropped it down a gear or put my foot on the gas again. I didn't think too much of it since I noticed the 05 rental Malibu i had made that noise too when i coasted down that same hill w/ no foot on the gas.
