onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Mon Jul 04, 2005 7:56 pm
Um, did you check to make sure your cold start wire is also getting power?
You have the primary ignition wire & the cold start wire -> this wire is often forgotten even by installers since the car is usually pretty warm when they test it (since they sometimes start it a few times, then it doesn't happen anymore).
Once I figured out the wire colors, I had to make sure I sent the power to it, so I set "accessory" -> "cold start", which is the secondary option for the alarm I had (Viper 791xv).
Easy test, once you find the cold start wire (it's posted somewhere here - I posted it a while ago, or you can check the12volt.com), you can hook everything up, but pull the wire for ignition/starting, etc & press the remote start on your alarm & multimeter the wires to make sure they are sending power - this way you don't kill your starter.
