DJBeasy wrote:And here is why I love this forum...
On Parkeroutlaw's advice I just went to Advance Auto Parts and picked up a tap and die set for $25.00, came home and fixed the thread in literally 5 minutes. Seriously, look at the time stamps on my previous and this post.
5497 I hate to be the bearer of bad news but I dont think you will be able to re-thread yours with the strut still on the car. The thread you are having issues with probably wont have enough room to spin the tap overhead. The one I had trouble with was nearest the fender and even I could only get about 4 turns until I started hitting other parts near the windshield with the tap handle. When I removed your issue bolt I could not even get a ratchet in there, had to use a flat wrench. Luckily it seems like my thread was only partially stripped so a few turns was all I needed. See pic below, wrecked bolt on left, good bolt on right.
Yeah, the one I have is in a tight space. I'm actually hoping that the strut thread is ok and I just need a good bolt. Then I saw your last sentence below....
BTW before people say that I didnt need to re-tap because only the bolt was stripped, not true. I tried 2 other good bolts with the same result.
Since I still have 2 good oem bolts here because I used the new ones that came with the bar, I'm going to try it anyways. Taking out the struct is not an option for me. I will have to seek professional help with that if it comes to that.
Btw, glad you got yours all fixed up. What strut bar did you get? How are you finding the results?
