Installed POP charger/clear turn lenses
joe603
Car: 2014 Durango R/T
It took about 1hour to do, only because I decided to take out the lower intake silence crap. Install was straight forward, and all factory parts came out without any problems.
What a change in sound!! It's nice and quiet under 5k, but get up in the RPM range, and it gives a loud snarl. The power is noticeable with the Z-tube, and would be even better with a nice CAT-back exhaust. I'm definitely happy with the fit and finish, and especially like the fact that it uses the factory "ram-air" piece.
Check out the pic!
joe603
Clear turn lenses...
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Looking good. I have those exact mods on my G, plus the 5/16 plenum spacer from Motordyne Engineering.
joe603
Was the plenum spacer worth it? I was thinking about just getting an aftermarket plenum for a few more bucks...
RED_DET
Vendor
2011 Infiniti G37x
I can honestly say it was worth the money. It compliments the pop charger. Now I need to get the exhaust taken care of and all those mods should come together like peanut butter & jelly.
joe603
Are you still able to use the infiniti engine cover?
Yes.
I have the Motordyne 5/16" spacer and it's well worth the $. I believe Intense (our sponsor) has a good deal on them.
I also installed UR lightweight underdrive pullies...
Adding the Stillen intake and exhaust should, as RED_DET said, pull it all together.
RED_DET
Vendor
2011 Infiniti G37x
AZhitman wrote:Yes.
Ah, Mr. Secret modder here!! How you like the lightweight pullies? Did you get the set or just the crank pulley? Where did you purchase?
Yes, Joe, I was able to re use the cover. It was a tighter fit, definately wouldn't be able to use it with 1/2 spacer.
superjv1080
Car: M45 + FX35
Now get the clear blinker bulbs from Stealth Auto. http://www.stealthauto.com/Sto...=SBCA They are silver coated but light amber (so it's legal).
