Yeah Phall
Phaal wrote:I don't know if the harness for your car is the same as the 08 but I had the same problem because the antenna wire in the harness was pushing out instead of connecting when I was putting everything together.
i
Yeah Phall is right, I was having the same problem after I installed my JVC 810 with the HD radio adapter. I thought HD radio required an insane antenna, but I found out that altima coupe radio harness are retarted, everytime you plug it in, it pushes out the black connector. WHat I did was pulled out the black cord from the connector(the other motorolla end goes into your head unit) and plug that directly into the Middle plug of the Nissan radio adapter(the slot that was getting pushed out when connecting the harness) Then, you clip the tiny wire on the left of the harness(suppose to connect to the blue cord on the harness) and after you clip it, connect that to your blue cord on your head unit. PM if it sounds confusing.
