Yes you need to set the injector lag time for the new injectors with the commander.420_240 wrote:started at approximately 4pm (sat afternoon)... finished approximately 7am (sun morning)... me, sparksta (brandon), and another friend of mine worked on the car all night.We installed the following:-nismo 555 injectors-HKS gt-rs turbo kit-unplugged and reset the PowerFC(still have yet to install the PowerFC boostCntrlR
After finishing the install we started the car up... let it run for about 15 minutes... then decided to take a drive...
turbo would spool to about 5psi then begin to stutter/power loss/no response
took the car back to the house... checked vacuum lines, re-adjusted fuel pressure (43psi-w/o vacuum)... disconnected battery, drained power (pumped the brakes a few times)... reconnected battery and let the car run for another 15 minutes.Round 2: drove the car up the street a block.... everything good... then POP... loose intercooler coupler popped off.... took the car back to the house... tightened the coupler back down and double checked the others.Round 3: drove the car up the block... everything is running smooth... hit boost at 12psi... came to a stop... checked the FC and knock reached 165!!!!! Drove the car back home off boost and parked it... The car hasn't been tuned in any shape or form yet. I'm not sure if i need to set the PowerFC to let it know the injectors are bigger or what....
Just thought I'd let you guys know how the progress was going... I've got plenty of pix and i'll post them as soon as I get them uploaded.Any thoughts/criticism/compliments are as always welcome.-Andrew
So does this mean where it lists all injectors at 100% and the lag time at 0.0ms.... i add 66.7% to the 100% that's already listed? 166.7%?Loveless wrote:I beieve you can set the duty by divinging the stock size by the new size... so 380/555=66.67%
Ok i'm beginning to understand with some help from the PFC manual....rb25det stock injector size is 370cc.... soooooo....If changing primary injector volume to 550cc/min and the injectors lag time is .am/s (a=unknown, but i have read it's .58m/s)Loveless wrote:no, what I meant is that you should set all 4 injectors to 66.5% for 550cc
740cc woule be 380/740=51.4* round off to the nearst 0.5 which woudl be 51.5%
I just read your mod list and you have rb, I don't know what RB injector sizes are but you need to take that number and divide by upgraded injector size
can someone explain why to set the lag time at 102? and what is this "hex value" ?
RX-7s run off 2 primary injectors and 2 secondary injectors. so just ignore that stuff.420_240 wrote:Loveless: I started reading something about what your saying in the english version of the PowerFC manual (for rx7)... also what is this i read about primary and secondary injector settings on the PFC?
It's the knock count and 15 is pretty good.Loveless wrote:at 7k rpm, my knocking peaked at 15, is that good? I have no idea what this means, 15 times a second? if knocking is at 15 does that mean I have low detonation?
also, injectors duty peaked 65 something percent. is that out of 100% or the 66.5% I configured for all 4 injectors?
