Installed replacement receiver, blinkers not working
Gatorash
Car: 2002 Pathfinder LE
Hi all! Hoping I can get some help with a problem. This forum has already been a great help, but i can't find anything on this. We installed a new reciever in my 02 pathfinder, and now the turn signals aren't working. The emergency flashers work, but not the signals. I'm at a loss. Any thoughts on what it could be? Thanks in advance!
themadscientist
Different relay for each I beleive. Did you disconnect the battery before you installed the head unit? You might have popped the blinker relay.
Gatorash
We did disconnect the battery. Husband checked the fuses and they were fine, then late last night (had to buy groceries) they started working again randomly. So weird. It took us 2 days to get it finished, and we disconnected the battery both times. The morning after the first day (everything still taken apart) was when they stopped working. They still didn't work after we put it all back together, then randomly started again. Hope it stays that way!
