installed my intake but couple of concerns/questions
D_roc
Car: 2001 Maxima 20th aniv edition
ok finally done but i noticed (the valve i circled) had some oil coming out so since the tube is connected tot he intake and it sucks in will it suck in oil through the throttle body and ruin it so what can i do about it?thanksD
johnnyd6404
Car: 2004 G35 Coupe 6MT 2k2 Maxima SE(sold) 2005 Altima 2.5S
I think you have it backwards I think that is a vacum line and the air flow from the filter is sucking out of the engine it could just be comming out of the engine. Its like if you blow across the top of a straw and put your finger at the other end you should feel the vacum effect. I'm not totaly sure about this but you would have to have oil moving against the incoming air (kind of like pissing into the wind) and up into the tube for that to be possible. So I think the throtle body isn't in danger but like I said I'm realy not sure.
