kmckis1029 »
https://forums.nicoclub.com/kmckis1029-u103545.html
Mon Dec 22, 2008 4:46 pm
The only complaint i have had about the BOSE system was the lack of/drowing of the Highs by the Low and Mid channel... you have to run the Bass at +2 and the Treble at +5 for the system to be half decent.
I recently saw a thread on a aftermarket tweeter install and decided to try it. I went to my local Audio shop and purchased some Memphis Street edge Tweeters for $32.10. (I didnt feel like waiting on shipping... probably could of paid less off the net)
All i can say is WOW the BOSE system is greatly enhanced... the whole sound stage is improved!
You can now hear the Highs with the treble set at zero! so im running the EQ at +2 Bass and +1 Treble (just to give it some amp power)
If you been complaining about the BOSE system and dont want to spend big bucks... just replace the Tweeters. I will still do a complete replacement later on next year but this will hold me over til then
here are some PICS of the install
Had to modify the bracket to fit the new tweeters
New Tweeter installed with a slight Bend on the bracket, a very snugg fit
Re-wired new tweeter (yeah it was 43 degrees out but i was determined)
All mounted back up... just need the screws and covers back on
Close up of the stock tweeter.. BTW it says 4ohm on the back??? thought everything was 2ohm????
Modified by kmckis1029 at 7:01 PM 12/22/2008
