Wassup guys . I currently have a KA-T setup . I just got my ecu and injectors back from Jim Wolf. They flow tested my injectors to make sure it was all ok and also tuned my ECU.
So yesterday I installed the ECU , injectors and a z32 maf. The car started up put instantly puffed white smoke with a strong gas smell. I assume that it is running rich . I spoke with Jim Wolf and they told me to check a couple things.
The first thing that I did was pull off the fuel rail and injectors and turn the key on to make sure that there were no leaks and there wasnt any.
I remove the spark plugs and theyre all wet with gasoline.
The best way I can describe how the car sounds is PUT PUT PUT PUT PUT
Can you guys give me some advice on how to troubleshoot this problem ?
