yeah didnt i just see a thread with a guy saying he figured out his maf was going crazy cuase the turbulance from the turbo was coming back to the maf?nizmo zilvia wrote:Your MAF seems to be a bit too close to the turbo. Try another 6 inches or so.
I am running the exact same size hose as what I removed. 5/8" I believe...CursedGTR wrote:I have had the MAF right on the turbo in the past without any issue whatsoever.
I have toi ask though, did you put your IACV on the new set up with proper sized hose?? I cannot see it in the picture but I would venture to say that you should check that (all I can see is what appears to be an orange silicon elbow). If it is on there, try adjusting it. If it is not on there than you should put it on or find another wany to get suitable airflow into your motor at idle.
Cool. I will look into that. I've only seen pictures but haven't looked any further into them. Thanks.240z4u wrote:Something doesn't look right with your PCV setup. Do some searching on catch can setups. Its beaten like a dead horse and I don't feel like getting to far into this.
Evan
Thanks Carl, I was too tired (read lazy) to explain it last night.Carl H wrote:the pcv valve keeps air out of the intake mani under boost and keeps the block from getting pressuized but under vacuum the pcv valve is open and drawing in unmetered air.
Thanks Carl. The car was kind of finicky when coming off the throttle. So like you said I blocked off that exhaust side valve cover.Carl H wrote:the pcv valve keeps air out of the intake mani under boost and keeps the block from getting pressuized but under vacuum the pcv valve is open and drawing in unmetered air.
Mine wasn't cutting out under full boost. Mine was just fine. Only thing I can think of is when your under full boost you may be having spark blow out. If you havent checked your spark plugs, I would check them and see what they are gapped at. But I also dont want to be telling you thats it. It could be a number of things. Thats just what comes to mind.dwnshfter wrote:sorry to hijack the thread, but mine is the same way. shift_garage, the place that ripped me off (more on that soon) said it was not an issue.whe i am totally ougt of boost, it lugs a little, in boost its fine, and at full bost, it cuts out really bad....would this be my issue too? what all needs to be done? ust install a pcv valve or does it need to be run into the intake or.....
is your BOV recirculated ? that's probably your issue there.dwnshfter wrote:sorry to hijack the thread, but mine is the same way. shift_garage, the place that ripped me off (more on that soon) said it was not an issue.whe i am totally ougt of boost, it lugs a little, in boost its fine, and at full bost, it cuts out really bad....would this be my issue too? what all needs to be done? ust install a pcv valve or does it need to be run into the intake or.....
unless your car was tuned for open-to-atmos bov, you need to recirculate your bov.dwnshfter wrote:not even a little bit. shift_garage said it didnt need to be.
