Installed Injen SES now VDC OFF, RAS, SLIP and SES lights are on
Onikage
Car: '06 G35 Coupe
I installed my Exhaust last night, Nice simple thing to do in comparison to doing the headers, test pipes and intake a month ago. But of course when I go to turn the car on afterwards it didnt want to start without a nice tap on the gas. When it did turn on I had the VDC OFF, SLIP, RAS and the SES lights turn on in the dash. Any suggestions? I believe it could be the grounding wire as that was the only thing electrical touched during the install
joe603
Car: 2014 Durango R/T
Welcome to NICO!!
I would try an ECU reset first, then check the O2 sensors. If the dummy lights come on after the reset, take it to a dealer to find out which system is causing the problem.
Onikage
Car: '06 G35 Coupe
I dont see how O2 sensors could be a problem. havent touched them in forever, well a month, will try ecu rest and let you know
Onikage
Car: '06 G35 Coupe
ok i reset it, it was a ***** starting it because i had to pump the gas for it to even want to start. its been idling for 4 or 5 mins and i dont have all those lights on. im going to go for a short drive and see what happens
G_whizz
Car: 2010 G37 Coupe Sport
Keep us posted!
Onikage
Car: '06 G35 Coupe
ok well i got the lights to go off and everything was fine driving. I ended up tightening the nut the holds the ground too. i came back home and turned it off. i still had trouble starting it and when i did the lights came back so i reset and started it again. I would love to know why my car wont start without pumping the gas
JeromeS13
Car: 2008 Subaru Impreza STI
I believe there's a known issue with something on the throttle body (I think the TPS). It should be covered under warranty.
-Jerome
Onikage
Car: '06 G35 Coupe
even if this is true im sure they will say. well you changed the intake, headers, test pipes, and exhaust so it voids warranty
infinititech1
lol we did it at our dealership with all those parts on there
Onikage
Car: '06 G35 Coupe
Ok thats great, now how do I find out if thats the problem without it costing me money like the hundred dollar diagnostics fee at infiniti
G_whizz
Try emailing Drew (Infinititech) he is on here so sparatically... just click his name
JeromeS13
Onikage wrote:Ok thats great, now how do I find out if thats the problem without it costing me money like the hundred dollar diagnostics fee at infiniti
You've got an '06. There shouldn't be any diagnosis fee, as it should still be under warranty.
-Jerome
