Doesn't matter one bit.alphapig wrote:Yep, it's auto CVT.
Does that matter as far as intakes go?
SHIFT_COUPE wrote:I have the black Injen and I got a polished heat shield. Go figure. Trade ya?
Tyler, I'm almost positive I read that the injen intake doesn't fir the 2.5 6MTSHIFT_COUPE wrote:
No. Aftermarket intakes do not void the warranty. The only time Nissan can say anything about warranty is if the aftermarket part itself caused a mechanical problem. About the only thing they could "void" replacing under warranty would be if you had MAF problems after the install.jak0 wrote:Do intakes really void the extended warranty? because if that is the case,, i will have to take mine out too
Probably because the Max had several more mods readily available. Unlike the Alty Coupe at the momentaudtatious wrote:Interesting what order people did what. I did my springs, RSB and FSTB first (in that order).
The Alty needs some suspension work too. Not so much for the ride, but to get rid of that FUGLY fender gap up frontaudtatious wrote:More like the Maxima NEEDED suspension mods first
Damn thing was a floaty biach when I first got it.
