float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Mar 21, 2006 8:13 am
Not to rain on anybody's parade, but it seems to me like the recent rash of headgasket problems seems to be all associated with the cometic HG. I'm running an OEM HG, w/ARP headstuds. I haven't had any sealing problems of any sort and my motor is high compression and has seen as much as 16psi w/o any problems.
It looks like it was installed correctly, the only other things that would cause that would be bad mating surfaces (did you get the block AND the head resurfaced?), stretched headbolts (I don't THINK the OEM headbolts are torque to yeild, but I could be wrong), bolts torqued to the wrong specs, or torqued improperly, or the gasket could be bad, which I highly doubt.
