Installed Haltech, no spark
A forum for owners and fans of the legendary Nissan Skyline and Nissan GTR.
whitetiger777
Car: 1990 R32 Nissan Skyline GT-R
So I installed a haltech and a set of 850cc injectors, but when I went to start the car it won't start. It looks like it's not getting any spark. I put the stock ecu back in and it runs, badly due to the bigger injectors, but it runs. Put the haltech back in and no go again. I noticed that it wasn't registering any rpm while cranking. Any ideas?
whitetiger777
I guess I should mention I have a Viper alarm system in the car. Not sure if it's the issue since I can still get the car to work on the factory ECU.
MiamiR32
Car: 1989 Nissan R32 GT-R
2014 VW Jetta
What else did you do other than just "install" the Haltech and 850cc injectors? There's a whole slew of processes you have to do to just get it going. BUilding out maps, etc.
whitetiger777
The car is pretty much stock except for the injectors and fuel pump. I also redid the entire engine harness with Wire Specialties. I'm also using the base map that haltech supplies for the car. It's supposed to be a guaranteed start up
whitetiger777
Total List of Mods
Tomei Fuel Pump
New Fuel Filter
Fuel Injector CLinic 850cc Injectors
Wire Specialties Engine Harness
Haltech Platinum Pro Plug In
Split Fire Coils
Nismo Down Pipe
Custom Test Pipe
Innovate Wideband O2
Veilside Cat back
Viper Alarm
whitetiger777
So I called haltech and they suggested because of the after market harness the cas might not be pinned right. How do I check that?
MiamiR32
2014 VW Jetta
Whether its pinned correctly or not (CAS) you still have a fuel pump and injectors providing WAY too much flow for even the base map that Haltech provides. Keep in mind the base map is meant to just get her started, don't do any driving on it (maybe down the street to the shop next door).
We spent a solid hour building maps and redefining the parameters for injector settings since I also put in new injectors (1100cc). The base map is junk after modifying the injectors, i think stock are 480cc?
whitetiger777
Ok, but we changed the flow rate to 840cc. Also we checked at the plugs and no spark
whitetiger777
Is there a step by step instructions for checking the cas with an oscilloscope?
fergyr31
Car: R31 Skyline GTS-X and GTS-R
If your CAS is working with the stock ECU then it is pinned right. I highly doubt it's a CAS issue. Also, with the HALTEC installed, take the CAS off and spin it. You should hear your injectors fire.
whitetiger777
Update: So finally Haltech sent me a B-Stock unit to swap out wit mine. The car almost ran with the B-Stock computer, figure it didn't completely run due to need of a tune, but it sounded like it wanted to run and I am now getting RPM's.
M35Squirrel
Car: 1990 Nissan GT-R
2011 Infiniti M37
any update on the Haltech? would you recommend? or should I go with other plug n play like AEM or Adaptronic?
whitetiger777
Had to be a bad box. They kept insisting otherwise, but that box just didn't work. They've now sent me a new V2 box and it works, however my tune didn't really transfer over so now I'm looking at paying for 2 tunes over the course of 2 months. Not really happy. This could of course just be a fluke since everyone else loves this computer
M35Squirrel
2011 Infiniti M37
Another question. Haltech's website says the Platinum Pro works with factory MAF, but when I talked to a local certified tuner he told me Haltech only works with MAP sensor plus wideband. How has your been tuned?
whitetiger777
It will work with the MAF's, given their unreliability I chose to have the car tuned with the map and o2. It will work with the MAF's though
M35Squirrel
2011 Infiniti M37
Thanks for the information. I think unless I'm shooting for more than 400hp, I will just get Nistune instead.
Return to “GTR Forum / Skyline Forum”
