Ka24DET-S14 »
https://forums.nicoclub.com/ka24det-s14-u170234.html
Thu Sep 08, 2011 10:28 am
Hello guys. I installed dual flexalite fans with a variable speed controller with a koyo aluminum radiator on my KA24DE along with an electronic water temperature gauge and Im noticing that my temps AT IDLE reach 220-225 degrees. I have bled the system properly and have the correct coolant/water mixture. I installed the temp gauge probe on the upper radiator house near the stock location of the OEM temp sensor so my readings should be good. Once I drive the car the temps drop to 190 degrees solid, but once I idle the car it goes upto 220ish. If I step on the accelerator while the car is idle and not moving the temps behing to drop back to 190. Is this normal? Anyone know the normal temperature range of a KA24de? My fans engage at the right temperature and blow a ton of air.
Any info will be appreciated! Thank you!
