Black R »
https://forums.nicoclub.com/black-r-u10322.html
Sat May 26, 2007 9:05 pm
A little background so my dilemna makes a bit of sense:
I bought this s13 from a guy I've known for a few years. He said he originally bought it as a daily from another guy who had TEIN coilovers on it and was into drifting it. He promptly put 'stock' suspension on it and sold the coilovers. He daily drove the car as a daily beater while he worked on his rb20 s14. When he was finished with his s14, he put this s13 up for sale. The car hadn't been well taken care of, but I was hoping to restore it and eventually make it track ready.
It needs a lot of work in many areas, and of course had rotted out TC (tension) rods as well as shredded boots on the tie rods and tie rod end balljoints. I bought those items and am installing them at the same time I have the car up to put on a set of eibach sportline springs. I bought these springs because I wanted to lower the car as much as possible. Yes I've read how low the sportlines are supposed to be, and that's why I bought them. I didn't mind if they would kill the shocks soon, as it would give me an excuse to get some koni yellows. This way I can have a low suspension now, and upgrade to ground control coilover sleeves in the future as I slowly build up the car.
pics of the stuff to be installed:
before:
after:
And a couple of pics showing the rubber crap (dust boot pieces which were demolished) that I removed, as well as the difference between the stock front spring vs the eibach sportline:
so, wtf is wrong? *I only installed the front left to take a look and see how much the drop would be... well it's not much at all! i thought these were supposed to lower the car 2"+ and instead it's maybe 1 finger lower.
So what gives?
Is it possible the previous owner put the wrong parts (tophats, etc?) on the car before he sold it to me.....? (Maybe he put s14 stuff on this s13?) How can I check? Or did I screw up something when I did the install? How are the tophats supposed to be oriented? For example: the front left tophat only has LF stamped on it, but no arrows toward the front or the car or anything.....
*edit*
I just found this in an online search:
http://www.nissanperformancema...shtml
Quote »On the front strut, one side of the top of the strut body is a flat edge. There is a small locating "pin" that uses the flat edge of the strut body to locate it, and there is a hole in the upper spring perch that is used to position the shock body and spring perch, as noted in pictures 9 and 10. Please note the "notch" that is pointed out in picture 9. When properly assembled, the two notches on the left and right struts are supposed to point directly to each other; in other words, the notch faces the engine. If you install it in a wrong direction, not only would the springs be improperly seated, you can also risk damaging the shocks.
Reattach the upper strut rubber insulator, and secure the 14mm bolt at the top of the strut. The now-installed strut assembly should resemble picture # 11. If you tried doing one strut at a time, without completely jacking up one end of the car and removing both struts/shocks at the same time, you will have a very difficult time reattaching the shocks. That is because the anti-roll bar is still attached to the lower control arm and is fighting your attempts at lowering the suspension even more. But, with both sides of one axle up in the air, putting the front struts back together should prove relatively painless. A tip: when installing the two lower bolts, attach the lower bolt and "swing" the strut so that the upper bolt holes line up. Makes the job a lot easier! [/quote]Hrm... maybe I need to press on and see if the front swaybar is preventing the left side from dropping all the way down until I put the other side on?
Modified by Black R at 3:44 AM 5/27/2007
