Silvia2b »
https://forums.nicoclub.com/silvia2b-u2470.html
Sat Dec 03, 2005 11:14 am
I have been keeping my car in the garage for the last few weeks because the brake light would come on indicating that the fluid level was too low. I inspected the calipers and didn’t find them leaking and there haven’t been pools or even drops of fluid on the cement, so I knew it was time to replace the pads and or turn the rotors at my local machine shop.
When I removed the wheel and checked the pads the there was less than 1/8th ” left of the friction material, that is what I was suspected.
The last time I did my brakes the rotors were the OEM rotors and in poor shape ready for replacement, the pads were organic but probably factory OEM. I decided to use semi-metallic pads because they are inexpensive, and replaced the rotors. The rotors were difficult to find for the SE in a 5 lug every auto parts store (Schucks, Kenchts, Autozone) I went to had some in stock, then when I arrived I had them open the box and guess what? All were 4 lug! Then I ordered through a Napa auto parts store, they came twice but were for a 4 lug hub. Finally the correct one came and were installed. These rotors had some significant wear on them now due to the semi-metallic pads, they also created a lot of brake dust.
I was browsing through The Tire Rack website and found that they also supply brakes and suspension in addition to wheels and tires. The brembo replacements were not very expensive and I figured that Akebono ceramics would be a good brake pad without causing as much dust to accumulate on the wheels as the previous ones. There was shipping problem with UPS, due to the Thanksgiving holiday I guess, but the products still arrived in 10 days.
I got around to installing them yesterday. I was curious about a small metal clip I found wedged in the vents from the inside of the rotor bell.( see picture below) I wasn’t sure if it was intended to be there due to poor balance or if it was to hang a tag on the rotor. I just removed it. I figured if is not balanced I would feel while braking with them installed. So here is the final assembly. Does anybody know why that clip would be inserted in the vents?
