Installed aftermarket CD player
ssjnimma
Car: 2007 Nissan Sentra SE-R Spec V (Black)
Hey just new to this group. Ive been looking and looking for topics about the 07 sentra... and i found this site to be very interesting in topics and responses. But anywho...... i installed my new Pioneer DEH-P7900BT looks amazing in the car... i was wondering how it would turn out and look but is sweet. I will work on getting some pics posted so everyone can see it. My question is has anyone else installed a sub in the back? i also did that on this install and im having a really hard time getting the plastic floor panel by the trunk opener to fit back on.I think the 3 wires are to thick for it to snap back into place.... all the other pieces fit fine, but that one piece... has anyone else had this problem???
maxima8347
Car: 2007 Nissan Sentra 2.0
Hi...could you please explain how you disassembled the dash for your aftermarket install?
ssjnimma
do you have an automatic or stick? either way im sure it would be about the same....
you first need to pull of the panel around the shifter, it just pulls right off with a little strength. then you can take off the climate control panel by just pulling it straight towards you. the radio is secured by two bottom screws you then unscrew those. then you get behind the two gauge pod part and there are two tabs in the back you need to just snap out. i used a flat head screwdriver and the tabs are towards the edges. it may seem like your going to break it, but ur not u just need to pry at it a lil bit and it will go. you also notice the plastic will look like it wants to bend, but its some tuff stuff... so no worries.... you will need to disconnect the cord going to the gauges and set aside. now theres two screws for the top of the radio, u need to remove those. all radio screws are phillips screws by the way. And thats basically it... that will remove enough so you can change out the factory radio with a new one.
ser07specv
i bought the pioneer dehp49001b please tell me what wires connect to what oh n y the way i have that sme problem i think it is cuz the wires r to thik
ssjnimma
what wires are you wondering about? because all you need to do is buy the wire kit, and it just is color coded. And are you reffering to my panel problem with the amp wires? yes that sucks, well let me kno mang
ser07specv
ahh tru tru lol i didnt hve anymoney at the time so i cut the stock clip so imm hve to buy new one from the dealer then and jsut play round with those mp wires itll eventually clip in
