LegendRacer wrote:engine service light is usually for oil changes... could be a coincidence right after ur install
just click thru ur service hting on ur dash cluster computer and reset the reminder, or turn it off
What
The SES light is not the service reminder on the display. SES (service engine soon) Is a light triggered by different fault codes throughout the car computer systems.
Sick_Coupe wrote:can it be because i started the engine without pluging in the maf by accident ? so i can just get the code deleted right ? with a scanner ?
That would most definitley be the reason why. Unplug your battery for 5 min, then reconnect it, and start up your car. You should be good to go from there
Also, after you unplug your battery, you will need to reset your auto window feature.
1. Push the ignition switch to the ON position.2. Open the window more than halfway byoperating the power window switch.3. Pull the power window switch up, and hold it toclose the window. Then hold the switch 3 seconds more seconds, after the window is closed.4. Release the power window switch. Operatethe window by the automatic function toconfirm the initialization is complete.5. Perform steps 2 through 4 above for otherwindows.
