installation of Blox spacer and engine damper(ebay)
4drmadness
Car: 04 g35 infiniti sedan
Hey guys could some one give me installation instructions on the blox spacer and engine damper. thanks for your help.
awdjdmtalon
Car: 04 G35 Coupe, Diamond Grafite Metalic, Aero package, 6MT
use the BIG RED FLASHING search at the top of the page.
TeflonG35
Car: 2003 G35 Sedan
Ive been drinking so I might not be the best help.
Take off the engine cover. Remove the tube from the throttle body. Unscrew all the bolts around the plenum. Lift the plenum. You may need to unplug some vacuum hoses and coolant hoses to give you more room to move. Insert the spacer and screw it all back together. DO NOT OVER TIGHTEN THE BOLTS! Reattach all the hoses and the tube to the throttle body. Put the engine cover back on if you want.
Should be everything.
4drmadness
do i need to get sealant for the spacer?
BrandAidDesignG35
Car: 04 Infiniti G35 Sedan
Not required, Blox spacer is a gasket, essentially.
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
4drmadness wrote:do i need to get sealant for the spacer?
not required, I used some for mine
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
I'll be there on Saturday. Make sure you set some time aside to do everything.
4drmadness
for sure man. let me know what time you are plannin on coming down. you have my address already right?
Sentientbydesign
96 I30 - Sold
Yeah. I have your address.
I'm thinking around 9-10am. Is that too early? One of the other moderators will possibly pass by so I can give him his kit too if that's ok with you?
4drmadness
thts fine man, you can drop by then, and the moderator can pick up the kit as well.
4drmadness
hey nate, all the tools are at my friends house who is busy till 10:30 on saturday. is it cool if we drive over to his house from mine? If thats too late then i can go get all the tools on friday or something. you can also give the moderator my friends address which i can email to you and he can come over there. let me know if this sounds like a plan
Sentientbydesign
96 I30 - Sold
That's fine with me. Email me the address.
4drmadness
email sent
tollboothwilley
make sure you report the differences you feel with the added mods afterward
av8or
Car: '07 FX35 AWD ... '06 4runner limited ..... A320 F.O. (my other ride)
tollboothwilley wrote:make sure you report the differences you feel with the added mods afterward
please do... i'm also considering installing a plenum spacer myself
tollboothwilley
av8or
just do the plenum install....you'll notice faster revs and more HP especially in the top end.
I say go with the 5/8" BLOX...only $100, so it will save you a lot of money and works great.
TeflonG35
Car: 2003 G35 Sedan
Oh. And let your engine cool before working on it.
