install welcome/courtesy lights in my 23 Rogue's doors
kennyhoang
Car: '23 Nissan Rogue
Hi
I was looking to install welcome/courtesy lights in my 23 Rogue's doors. T33 doesn't have an existing light. I want the lights to only turn on when the door is open. Is there any way I can tap the connections from inside the panel?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If the car already has mood lamps then you can tap the wiring for those. If not, see if positions 11~12 are loaded on one or both sides of the door connector.
kennyhoang
VStar650CL Thank you, You are the best.
VStar650CL
Technical Expert
:dblthumb:
Return to “Rogue Forum”
