Cold_Zero »
https://forums.nicoclub.com/cold-zero-u2277.html
Mon Jun 16, 2003 4:50 pm
Last night we (local Impreza Club) put in my Perrin Up-pipe and Invidia Down-pipe. For a brief moment in time, my WRX became naturally aspirated. I have a few observations about our install day:
1. Never go first on an install day. As we took apart my car to get it ready for the install, we remember all the things we forgot to reconnect to Jake's car.
2. A hair dryer does wonders with getting intercooler hoses back on to the turbo. The stock (rubber) intercooler hose does not reconnect to the turbo all that well on the WRX. If you use a hair dryer to heat up the hose, it connects really easy. You do not have this problem if you upgrade to silicone intercooler hoses.
3. When a guy brings a beer keg to the install day, be very afraid. The Japanese exchange student in our club brews beer and brought a batch to the install day. Nothing like 9am on a Sunday morning and you don’t know what the heck you are installing.
4. A cracked ratchet socket will strip most bolts. In an attempt to unbolt my passenger side motor mount, I stripped the nut. After further inspection of the socket, I had cracked it. Always inspect your sockets before you use them. I am not sure how I am going to get my motor mount nut off.
5. It is not a good idea to jack a motor up using the oil pan. We bent my buddy's oil pan with a car jack trying to up the motor. And yes, we did use a block of wood to create a platform.
6. Read differential protectors make great jack points.
7. Use liquid wrench or WD40 sparingly when trying to unseize nuts. My buddy's WRX is still smoking from the WD40 we sprayed on the turbo bolts to get them free.
8. It is better to do an install of parts when the car is still new. Freeing up the bolts is much easier.
9. Removing a turbo is a very messy project. Because we couldn’t jack up my motor to get to the stock up-pipe, we had to remove the turbo. We had coolant and oil everywhere.
10. All you 240 guys be happy that your motors are in-line longitudinally mounted. Working on a boxer engine is a pain. They have crammed so much pluming and engine components into a very small engine bay.
I am glad this project is done. We got done at 11:45 and I had to wake up to go to work the next day. No exhaust leaks or CEL lights thrown. My car spools a hell of a lot faster and is fun to drive now.
