wow 6hrs, are you serious!??!! what do you mean buy fix it?soxypoo wrote: it will be a b**** if you have to fix it good luck
doesn't require exotic tools? lol i'm sure everyone has spring compressors laying aroundmrodrig2 wrote:I disagree, don't take it to a shop. DIY! So many people here don't have a lot of mechanical experience and this is a good project for them to get their feet wet. The install may be tedious but it doesn't require exotic tools or knowledge and is actually pretty easy once you get over the scale of it. Just be patient, follow the instructions and torque everything correctly. You can even split up the job and do fronts and backs on separate days if you are worried about time.
I vote for shop. Most people don't have spring compressors. Few have floor jacks. Even fewer have torque wrenches.mrodrig2 wrote:I disagree, don't take it to a shop. DIY! So many people here don't have a lot of mechanical experience and this is a good project for them to get their feet wet. The install may be tedious but it doesn't require exotic tools or knowledge and is actually pretty easy once you get over the scale of it. Just be patient, follow the instructions and torque everything correctly. You can even split up the job and do fronts and backs on separate days if you are worried about time.
When you do the install do the Rear one first because its easier and will give you more time to do the front. If you have all the right tools (deep socket and a breaker bar) you should be able to do the fronts in no time. If you are fast with a helping hand you can get the front done in 2.5-3 hours.johnnir3volution wrote:so how many hrs did it take in total? Im going to start working on them 8:30am tomorrow and hoping i would finish no later then 2pm
3hrs front 20minutes rear=!! most of the 3hrs were spent compressing the springs. keep us updated johnEvo!!(double/triple check your work dude)johnnir3volution wrote:so how many hrs did it take in total? Im going to start working on them 8:30am tomorrow and hoping i would finish no later then 2pm
ok-will do hey thanks for the tip! ill try to get cheapie camera phone pics up tonite when i get the time.bunda4th wrote:blackteam02,
Make sure after the spring settle in you go back and re-tighten all the bolts, just in case.
