89sxRCR wrote:btway, budd, howd your swap go? Are you all complete?![]()
Is your transmission auto if so beware of rebuilding problems then I warn ya!. Most rebuild shops make them work for a while only 1/1000 get it totally perfect and will last a good time. Find a junkyard transmission or a local guy that did a swap and his stock transmission is probably for sale. I went thru 2 trannys and 3rd just went last week. So I have decided to go the 240 route if I can find one locally.BuudWeizErr wrote:It's almost ready to go, all the hard stuff is done, for sure, driveshaft is on, shifter is in, slave cylinder is in... clutch system is bled. Need to put on my exhaust, cut the intercooler hole, and that's about it.
The only problem is now my Accord is giving me problems, something with the transmission, so the SR20 might have to get shelved for a while, possibly a long while if I have to replace the transmission. that would suck... bad.
89sxRCR wrote:how bout you stop queefing and suck mine. "Wasting time" is exactly what you and this thread starter are doing, the answers have already been posted before and unless you want to start answering all of these redundant questions using your superior intellect and history (19 posts), i suggest you SHUT UP.
goixiz wrote:
Any special tools i need and what else pls
Don't forget a big hammer...no job is complete unless you've used a big hammer.I H8 UR DSM wrote:hacksaw, torch, welding materials, and go to work : )
KFL wrote:Is your transmission auto if so beware of rebuilding problems then I warn ya!. Most rebuild shops make them work for a while only 1/1000 get it totally perfect and will last a good time. Find a junkyard transmission or a local guy that did a swap and his stock transmission is probably for sale. I went thru 2 trannys and 3rd just went last week. So I have decided to go the 240 route if I can find one locally.![]()
that180guy wrote:hooray for BuudWeizErr!!!!!!!!!!
We all wish we were at that level.
strap on the pipes, prime up fluids(course uve dun this already) crank her, "SHES ALIVE ALIVE I TELL YA", test drive, give urself a pat on ur back, tell yourself job well dun, and den down a nice cold brew.
