Same exact lines here, and I also used the silicone gasket. You could also use teflon, either way. Didn't your lines come with the washers though? copper washers, you should use those for the banjo and stuff.Well one piece of advice, because mine did leak when I installed them and had the motor in, MAKE sure to tighten EVERYTHING, and do not overtigthen them, try to be careful on that, some people do over do it and end up breaking them and causing a leak. But basically, everything is specific as to which goes where and to what, you can't really mix them. The banjo goes to the block, thats about the only one that might cause confusion. If you have pics, post them so we could check them outEmperor_Tha wrote:i have cs line, i just use silicone gasket on the thread.
yeai thought that but wasnt sure. the stock oil return is the rubber hose going into the bottme of the block.hayai_240 wrote:Actually 2 of the SS lines are for coolant and 1 is for oil. You use the stock oil drain line.
Heres a link that may help you see where that line is going behind the block. Look at the section where they show you how to re-route the heater hoses. In one of the pics you can see the coolant line that goes from the turbo to the metal hose behind the engine. This is what the SS line replaces and the reason why one of the SS lines comes w/ a clamp on one end of the lines.idahotuner wrote:
but i still want ot kow where that line is going behind the block.
