DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue Jan 25, 2005 10:21 am
Qdog is the only one who's done it to my knowledge. You'll have to remove all the plenum bolts to raise it high enough to get access to the injector. Replace the 8 rubber donuts under the plenum. If the alt bearing is bad probably best to replace the entire thing, unless you can get someone to rebuild it (not replace it) for cheap. For the labor involved I'd sooner replace it with a factory rebuild and be confident it'll be good for a while. Make sure it's not the idler pulley bearing. Those are cheaper and easy to replace.
