C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sat Jan 21, 2006 10:27 am
Remanufactured is kind of a grey area. But it's possible it was simply rebuilt. In this case the center section would actually be rebuilt. THe housings would simply be reattached as long as they weren't damaged from contact with the blades of either wheel. Cleaning up the parts isn't necessarily required, however a local turbo builder I went to gave mine a nice bath as it came back looking cleaner than when I got it(new). I'm thinking though, if you see one listed as remanufactured, it's probably just rebuilt. It's probably cheaper to buy a new turbo than to rebuild a turbo and replace housings and such.
While the swing arm for the wastegate may be of concern, the housing and parts don't make much of a difference unless it is structurally compromised(leaking air or interfering with airflow or the blades of either wheel, perhaps fitment issues as well).
The main concern will be the shaft play. If that's in check, the turbo should be fine for the most part.
As far as honesty, well it's possible he interchanged the terms rebuilt and remanufactured. Might have been an honest mistake. However, I generally approach everything with a level of skeptisism. And the reality is honesty is generally more expensive.
