Inspecting A CA18DET
krazy skwerel
Car: 1989 240SX Coupe down for the count
2005 Honda Accord
1974 Ford Mustang II
Ok so I might be going to look at this CA motor set that a guy has in town. Anything in perticular I should look out for? Thank you for your help.
float_6969
Do a compression test if possible. Pulling the oil pan or valve covers will tell you a lot as well. Look for oil coking. If the color of the aluminum in the head is very dark brown, the motor hasn't been very well taken care of and I would expect to rebuild it.
krazy skwerel
2005 Honda Accord
It is supposed to have 40k miles on it and was in an s12. Says the harness has some places where it is cut, but is still a complete harness just need to reconect the few wires that are cut.
float_6969
If it was a CA in an S12, then it's a CA18E(T). It's an 8V SOHC. Make sure this is a DOHC motor. If it's the single, I wouldn't mess with it.
krazy skwerel
2005 Honda Accord
I know the difference, the way he makes it sound is he had swapped in the CA18DET. lol I'm not about to buy an ET.
float_6969
Just checking!
krazy skwerel
2005 Honda Accord
It's all good I am just torn between this and a sohc kat build, but I have been trying to figure that out for nearly 4 years so damned indecisive.
tyrannix
Car: go big or go home
so do both
either buy teh CA now and drop it in and enjoy it while building up the KA
or
slap on a turbo to the KA, and have fun until you blow it up, then drop in a CA (or start building up the CA while driving the KA)
either way, do *something* and youll start having more fun in your car
we cant decide for you, but you can do a t3 flanged turbo and a cheap SSAC manifold (then lines, and piping) and you would more than likely be able to reuse the turbo, and piping for the CA
I will tell you this tho. when i got back to the states, i was |--| that close to turboing the KAE in the (93k mile) 89 donor car for my rebuild project., while i was waiting for machine work and little odds and ends. (ill share a blunder on my part that blew the HG on the KA tho. I took the MAF housing from a CA MAF and bolted the sensor from the KA onto it. within driving 50 miles like that the headgasket blew .....
but had that not happened, i would have been driving a KAET for a lot longer while getting the CA ready to drop in
so theres storytime for today. I would turbo the KA to get some more driving fun, while doing a hoss build on a CA
CJ
krazy skwerel
2005 Honda Accord
Thats way more money than I want to waste. Though it would be fun, the Government don't pay me enough to do that. If I can get this engine here in town I am gonna go CA. Always liked the engine. Hell even if I cant get this engine. I'll probly still go CA. Also this engine has 40K miles and he wants 1000 obo.
Modified by krazy skwerel at 3:58 PM 12/29/2006
Modified by krazy skwerel at 4:02 PM 12/29/2006
