Inside fuse box listing
stylesjas
Car: 2003 Infiniti QX4
Does anyone have a listing of the inside fuses for a 2003 QX4?
JPK Omaha
Car: 2003 Qx4
Its on the back of the coin drawer cover. There are two more fuse boxes under the hood
stylesjas
My unit is blank.
JPK Omaha
Car: 2003 Qx4
Which fuse are you looking for?
stylesjas
I will be looking for a parasitic draw on my battery tomorrow, and I need to know which fuses I will be pulling. The fuses under the hood check out good.
JPK Omaha
Car: 2003 Qx4
I took a photo, if you give me your number I can text the photo to you.
stylesjas
email would be better, if you can.
[email protected]
Thanks,
stylesjas
Found what the draw was. It appears to be the factory Bose amp. When I pull the fuse, the draw drops to normal. Now, I need to see if this amp can be replaced or repaired.
Thanks,
