kerrton »
https://forums.nicoclub.com/kerrton-u88348.html
Sat Jan 02, 2010 6:35 pm
What's the temp and humidy been like in your area lately? This can happen if you get temperatures that straddle the freezing mark (warmer during the day, freeze in the evening/night), and if you get wet snow or rain mixed in this can happen even more readily.
If it warms up during the day, and the humidity is fairly high, you park the car for the night and all the relatively warm, moist air freezes/condenses and releases the moisture into the air where it freezes on surfaces like the inside of the windshield.
Anytime you get temperature swings that straddle the freezing mark with higher humidity this can happen, just guessing this might be the case? This can also happen with heated garages, you drive away in the morning with cab full of warmer, moist air, park at work and when you come out at the end of day it's all frozen ice on the windshield.
Other than that, can you think of any other sources of moisture in your car? I think skiers, hockey players, or tobagganing on days where the temp is just above zero can cause this, everybody jumps in the car all sweaty after the game with their wet gear, drive home and park the car. Over night the temp drops, the wet sweaty air condenses and you've got the same problem.
Just some ideas, hope you figure it out.
