Inside dome and control panel issues plus more
SMcNair83
Car: 2003 Infiniti M45
Just bought a 2003 M45. The dome lights(front and back) aren't coming on and particle lights on the control panel are/aren't working. Plus the mirrors seem to be having a mind of its own...sometimes they want to work and sometimes they don't. Also the trunk release locks and unlocks within seconds :crazy: Any suggestions? HHHHEEEELLLLPPPPP
cruzad3r
Car: 2006 Infiniti M35x fully loaded
i would do the following.
1- test to see if you're getting power; if yes- new dome light, if no - need new switch - i suggest junkyard if you're near one or try online but then you have to wait
2- for the mirrors - it could be the switch or the actual motor itself. truth to be told, you bought a 10+ years old car so these things will be a pain to track down and fix.
if i was you, i'll replace the whole dam thing and call it a day.
Ilya
Could also be the BCM (body control module).
