Def »
https://forums.nicoclub.com/def-u8646.html
Wed May 12, 2004 12:17 am
I've got a pretty ambitious idea, but this is assuming outside clearance is NOT a factor. I repeat, do not have to worry about rubbing the fenders.
Would 17x10" wheels with a +12mm offset work on an S13 with coilovers(JIC, GP Sports etc.). I'm pretty sure a spacer will be needed up front, so a 15mm one should do it resulting in a -3mm offset. Not sure if the back will clear. It might need a 5mm spacer or the like.
So setup would be:
FRONT: 17x10" -3mm offset
REAR: 17x10" +12mm offset
Let me know if you guys think that will clear the inside part.
