deanm »
https://forums.nicoclub.com/deanm-u51595.html
Mon Dec 04, 2006 5:14 am
KenstyleM35,
That sounds like a very clean installation.
I'm thinking about mounting an Icom IC-208H in the trunk, with a small trunk-lip mount dual-band antenna, then putting the control head in the glove box like you did, or maybe in the ashtray area (which works if you don't smoke).
I'm curious:
The IC2720 must pull about 12A on transmit. Did you run a pair of wires directly from the battery to the trunk? How did you route them through the car to the trunk?
How did you route the control cable?
Thanks!
